- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hello people, I turn to the forum to see if any of you can help me with a little problem that I have and after several days trying to solve it, I do not get to anything.
The theme is that after modeling a 3D object, and performing the 3 fundamental views with the command solview - UCS and solview - ortho, without any problem, when wanting to make an auxiliary view of an inclined plane with the command solview - Auxiliary, when the view is projected, is not perpendicular to the projection line, but remains orthogonal, like a frontal view, or superior. I do not know if I explain correctly, but if they wish I can post an image so that they understand me better.
Thank you very much for your help !!
CLARIFICATION: I'm using AutoCad 2015 for students at MacOS
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Can you attach your drawing here?
This could help to solve the problem shortly.
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Sure! Here is attached. I clarify that I work with the system of views and projection of planes of Europe
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Looks like I was able to create correct auxiliary projection after I added temporary construction line for defining the inclined plane.
Please look at the attached drawing (I created a copy of your Layout in it)
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks for your help Maxim, but look, try to do the projection from a line that defines the plane, but the result is still the same, the projection line is well located, but the view can be seen orthogonally, here I attach a copy Of the file that you sent me, only what I did, was delete the viewport and generate the command solview again. (I clarify that when I try on another PC, I had no problem to perform the view), so I guess it will be some software error, but I do not realize that.
I also attached an image in which you can see how when I generate the view, the projection line (trace line) and UCS are well located, but still the modeling comes out at 90 degrees
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Can you create screencast of what happening on your side?
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Sure, Here I bring the screencast of the process, thanks for your time
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I think something wrong is with AutoCAD on your Mac.
For example, you have Realistic visual style in the viewport in which you define auxilary view:
But the SOLID object in the viewport shows as wireframe.
It should shows like this:
So I advice you to Reset AutoCAD and then try again with SOLVIEW.
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hello again, thanks for replying, but already try to reset AutoCad and reinstall it from 0, but nothing has worked, the same thing still happens, I will leave the subject open in case someone discovers some solution because this is driving me crazy
By the way, the viewports look like 2d wireframe since it also has the soldraw command applied
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Luciano,
OK, I see: the layer with the Solid object is VPFrozen, so it is invisible.
Anyway, I still cannot reproduce the issue you have on your side.
Looking closer at your screencast I noticed one strange thing:
After you pick the "side to view from" in SOLVIEW command, the crosshairs doesn't change its orientation to reflect the inclined plane - crosshairs remains "orthogonal", aligned with horizontal an vertical directions. But in fact, as soon as you pick "side to view from" crosshairs should rotate to reflect inclined plane:
I don't know why this happens on your side.
And additional question: can you reproduce the issue in every drawing or only in one, we are talking about?
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Maxim, so the pointer does not change its position until I select the center of the view, then it is set correctly but still the view remains orthogonal. It happens in all the drawings, try to create a new model in a new document, in other documents that already had but does not work either
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I am using MacOS Sierra fully updated and AutoCad 2015 student version, also fully updated (update 4). Restore AutoCad 3 or 4 times in these 2 days and reinstall it 1 time, and without touching any type of configuration continues giving this problem.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
BTW, if you have student license, than you can upgrade to the latest AutoCAD version - please look in your account page:
https://manage.autodesk.com/
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Yes, this is definitely an AutoCAD 2015 for Mac problem: I have 2015 version installed on my work machine and today was able to test SOLVIEW in your drawing.
And I was able to reproduce your problem.
So if you have an opportunity - upgrade to the latest AutoCAD for Mac version - 2017, I'm sure there will be no updates to 2015 version in future.
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Maxima
Thanks a lot for your time and help, you gave me a headache and now that I know that it is a CAD problem and not my Mac I will be able to solve the problem directly, I will see if I can upgrade to 2017, again, thank you very much For the help, I can just update and do SOLVIEW correctly, I'll let you know
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Well, already updated my version of AutoCad to 2017 and indeed, there was the error, in the 2015 version, as simple as that, but hey, I can work properly, haha
I appreciate your help, and I hope that you have been able to help anyone with a problem similar to mine
