188 Vistas, 2 Respuestas
autocad Architect LT 2014 Lost file
I have autocad Architect LT 2014 in my Mac computer. After 3 days of work the drawings file I was working on closed unexpectedly, and now I can only see the changes I made during the 3 days in paper space, but NOT in model space. Is there a way to retrieve the work and can you suggest a way to clean up the file if it is corrupted to avoid this from happening again. I tried several troubleshooting suggestions found on the website, but nothing worked.
Thank you,
Sergio
pendean
en respuesta a: Anonymous
Emmsleys
Hello @Anonymous,
Welcome to the Autodesk Community!
Checking in on your thread, were you able to find a solution or a workaround?
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Or post with any new updates if you need continued help on your thread.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
