- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi guys. I'm bit of a novice when it comes to AutoCAD so I hope someone can help.
I have some 3D DWG files of office seating that were created by someone else and need to create overhead plan view 2D DWG versions of these.
If I simply open in AutoCAD (I have a 30 day trial) and export to a file as a dwg via the FLATSHOT command, will this create the best version. Or can someone recommend a better process? See image.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
It looks like you are using autocad for mac. if you dont get a sufficient answer in this forum i might hop over to the mac forum and ask there
https://forums.autodesk.com/t5/autocad-for-mac-forum/bd-p/520
CADnoob
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
HI @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Here is a post from a while ago that addressed a very similar issue. If this doesn't work for you let me know and I can try some other steps for you. Is it possible to share one of the drawings by attaching it to a post?
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
OP already started new post here in AutoCAD for Mac Forum:
https://forums.autodesk.com/t5/autocad-for-mac-forum/converting-3d-dwg-to-2d-dwg/td-p/7074347
So this is double-post.
Plus - VIEWBASE command is not available in AutoCAD for Mac.
Maxim
Maxim Kanaev
Architect
MARSS
