maxim_k
en respuesta a: hanerZY6L7
Is it multiline text attribute?
I have similar issue with one of the block created on Mac side. After I opened and saved the drawing with this block on Windows side multiline attributes started to behave the same way as yours.
I have not found any permanent fix fot that. The only way is to use BOATMAN to Sync the block on Mac side, but once you open and save this drawing on Windows side, the issue starts again.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
