en respuesta a: pendean
The ## tag is for the att def that is embedded in the block. If I type in the att def, it comes out as (example) 1/A-100 as desired.
It just keeps moving off center, despite the att def in the block being defined as in the center if you open the block to edit...
Thanks for the attempt however, it appreciated!
@pendean wrote:
Font change perhaps?
FYI ## is a field usually means the object it was point to is no longer there.
