hanerZY6L7
2425 Vistas, 9 Respuestas
Blocks with Attribute Text offset, unable to fix
Hello, I have a block that I made for detail / section tags and the stacked attributions.
They were made in a windows environment and I am now a AutoCAD LT 2017 for MAC user.
I have entered the block and moved the attribute back to center, but it keeps floating to offset.
Any ideas on how to fix?
Pics posted. First is what is opening, second is how they are supposed to open.
Thanks!
pendean
en respuesta a: hanerZY6L7
Font change perhaps?
FYI ## is a field usually means the object it was point to is no longer there.
Emmsleys
Hi @hanerZY6L7
I see that you are visiting as a new member. Welcome to the Autodesk Community.
I'm going to move this over to our AutoCAD for Mac board.
Would you be able to share a sample drawing file?
Sarah Emmsley
Technical Support Specialist
en respuesta a: pendean
The ## tag is for the att def that is embedded in the block. If I type in the att def, it comes out as (example) 1/A-100 as desired.
It just keeps moving off center, despite the att def in the block being defined as in the center if you open the block to edit...
Thanks for the attempt however, it appreciated!
maxim_k
Is it multiline text attribute?
I have similar issue with one of the block created on Mac side. After I opened and saved the drawing with this block on Windows side multiline attributes started to behave the same way as yours.
I have not found any permanent fix fot that. The only way is to use BOATMAN to Sync the block on Mac side, but once you open and save this drawing on Windows side, the issue starts again.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
wei503
en respuesta a: maxim_k
If the justification of the attribute is using bottom center, please try others like middle center.
Wei Ma
AutoCAD QA Manager
hanerZY6L7
en respuesta a: Emmsleys
Hello sorry for the delay and thanks!
I have attached the sample CAD file if that helps, thanks!
hanerZY6L7
Hep MaximK, BOATMAN sounds like a potential fix.
Is that a command?
Even better is there a fix that lets blocks play nice with MAC and WINDOWS?
Thanks MaximK!
hanerZY6L7
en respuesta a: wei503
This doesn't work, you can move it inside the block and it still stays offset in the block once you exit the block editor.
Thanks for the help and attempt!
maxim_k
Sorry, there was a typo:
I meant BATTMAN (Block Attribute Manager) command:
http://help.autodesk.com/view/ACDMAC/2017/ENU/index.html?guid=GUID-4920952B-6809-49E7-956E-C6A94BEA6...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
