05-01-2017
10:20 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-01-2017
10:20 PM
Welcome to Autodesk Forums!
Hi Jerry,
Yes, you are correct COPYTOLAYER command still not available in AutoCAD for Mac.
But why not to use this method:
https://forums.autodesk.com/t5/autocad-for-mac-forum/how-do-i-copy-objects-to-a-new-layer-or-duplica...
Before using "Move To Layer" select objects you want to copy to another layer, then make a copy of them at the same place. Then use SELECT command with "Previous" option, than use context menu "Move To Layer".
After this you can also MOVE objects copied to another layer using "Previous" option in MOVE command.
Maxim
Maxim Kanaev
Architect
MARSS
Hi Jerry,
Maxim
Maxim Kanaev
Architect
MARSS
