en respuesta a: maxim_k
Hi Maxim,
thank you for you prompt reply !
In this tutorial they show the panel on the right as Properties Inspector 🕵🏻‍:signo_femenino: containing layers controls where we can change properties of layers.
Then a Layer Palette has been shown as expanded in order to contain more layers's properties.
Is it here ? In this window that I have to assign properties to a layer ?
Or in the lower part of the right panel ? :cara_que_ríe_con_la_boca_abierta_y_los_ojos_sonrientes:
At the end - following your clues and what I learned on the tutorial - I did manage to keep color and line type separated but :cara_que_sonríe_con_ojos_sonrientes: Should I tell you how I did it, I absolutely couldn't tell nor do it again
Maybe I just need a bit of practice
Thank you for helping out
I hope I can count on you again at my dubs
Thank you :árbol_caducifolio:
