2638 Vistas, 5 Respuestas
Autocad LT MAC - How to edit the right click comands and add additional tools.
Hi, I have been searching for a way to edit the Right click tools (currently there is ERASE, MOVE, COPY SELECTION....) I want to add some more tools that i use more frequently e.g. DIST / MIRROR / ETC...
So when right clicking over an object currently there is this - http://take.ms/i8ml3 (screenshot) - also attached
I have searched other forums but the nearest solutions i have found is as follows:
Useful to see that need the CUI command but cant see how to apply this change in AUTOCAD LT MAC
Link 1  - https://forums.autodesk.com/t5/autocad-forum/customize-right-click-pop-up-menu/td-p/3426383
This seems to be what i need to edit. But in the CUI settings dialog i cant see the options it is referring too ? See attached screenshots
Link 2 - https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Au...
I found the source of where the CUI files are saved. was hoping to find a way to edit these manually. But seems these can only be edited within the program? if so where? - Screenshot attached
Is this a limitation of the LT MAC version ? or is there another way to do this that im missing?
Any help would be greatly appreciated.
Kind Regards
Tom
