959 Vistas, 2 Respuestas
Help!!! Viewports to print to scale
 Hello all!
I am a student fairly new to AutoCad and cannot seam to figure out the viewpoints. I need to print each row on a single piece of paper at 1:50, how do I do this??
Thanks in advance for any help you can give me!
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
At first you need to set UCSFOLLOW system variable to 0 (zero) in Model space:
Command:
Command: UCSFOLLOW
Enter new value for UCSFOLLOW <1>: 0 <- type 0 and hit Return here
Then create layout and set in it paper size you need.
Now create viewport, activate it by double clicking inside viewport and roughly zoom to the area you want to see in the viewport.
Then use Status Bar to set scale of the viewport to 1:50, use pan to adjust view inside viewport. Activate paper space by double clicking outside viewport.
Look at layout with name "Layout with 1_50 viewport" in attached drawing.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Thank you so much, thats exactly what I need!
And thank you for braking it down for me, I can see now - seams so simple!
