2798 Vistas, 7 Respuestas
Lotus flower petal mesh
Hello
I am trying to create a 3d lotus petal from a closed polyline and an open polyline touching the vertices of the closed polyline.
I am happy with the 3d drawing as i have used plan and side view reference material to get it right, the problem i now face is how to create a mesh from it? I would like to sweep along the entire closed polyline at the top, and use the bottom line as a guide to create a curved petal shape.
Is there any way to do this?
Any help would be greatly appreciated.
Best wishes,
Berance.
(using Autocad 2013 Mac version on a mid 2010 macbook pro, 2.66 GHz Intel Core 2 Duo, 2.66 GHz Intel Core 2 Duo, 2.66 GHz Intel Core 2 Duo, 2.66 GHz Intel Core 2 Duo).
Etiquetas (5)
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Are you satisfied with the answer, posted here:
http://www.cadtutor.net/forum/showthread.php?100483-How-to-create-3d-Lotus-petal-mesh
If no, please attach the images of reference material you used to create profiles?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
I'm not sure exactly which shape of the petal you want to have, but here is my way:
See attached drawing for details.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
If you are more familiar with Fusion, you can do this in Fusion.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
g.isley
en respuesta a: maxim_k
Could you please tell me how you went from your drawing to the actual petal. I have tried every way I can think of to make the drawing into a petal.  Photo enclosed.
Thanks.
maxim_k
en respuesta a: g.isley
Do you use AutoCAD or Fusion?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
g.isley
I am using fusion 360.
maxim_k
Sorry, but I don't use Fusion and cannot help you.
I'd suggest you to ask your question here:
https://forums.autodesk.com/t5/fusion-360/ct-p/1234
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
