- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Breakline command non existent on Autocad 2015 for mac?
I've been searching for the breakline command but can't find it anywhere. I type it and the only commands available is break or breakup (explode). Can't find my express tools either.
Can someone assist me please?.
Thank you.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
try loading the lisp manually
(load "BREAKL")
if that doesn't work try drag and drop the file breakl.lsp from the Express folder under the AutoCAD installation folder directly into the autocad drawing area.
Hope that helps
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Breakline (along with 5 other commands from Express Tools) available on Mac only since 2016 version.
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Following up on your thread, it appears that several folks have tried to help on this issue. Were you able to find a solution? Or a workaround?
Did any of the posts in the thread help with your issue?
Please post back in the thread if you are still having an issue with AutoCAD or Select Accept as Solution for the post’s that helped.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
