john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
I opened your file and went to each layout tab. On each one, I created a Page Setup. For the large format (D-size sheet), I based the setup on a printer driver that I have installed for a HP Pagewide Plotter. I found that by installing this driver I can pick from it's sheet sizes and I have really good luck with that as opposed to creating custom sheets. If you have a different large format driver, simply go into each page setup and change the printer to that driver and then pick the D size. I also assigned your CTB file which I renamed to Adena.
Now when you want to plot, you will brin  up the plot window and use the Save as PDF in the bottom left corner.
John Vellek
