maxim_k
en respuesta a: Anonymous
Hi Tony,
I added thickness to the initial curve (0.1 unit), revolved this new curve and got 3D Solid which (inside red rectangle in your drawing) I was able to export to STL file (see attached Revolved Curve - low resolution and Revolved Curve-HiRes - high resolution).
If you need the horn with a smaller "wall" thickness, you need to reduce initial curve thickness - I colored it cyan.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
