621 Vistas, 4 Respuestas
Creating a Solid or surface from a mathematically generated curved line
Hi all.
Apologies first of all, as I am a total noob to CAD software.
My issue is that I am trying to get to the point where I can 3D print a few acoustic horns so I can explore the frequency cutoff of each one for my degree (I'm a Sound Engineering student).
I have a specific curve thats been generated mathematically (Base Curve.dwg). From here I have tried several ways to revolve the curve around the central axis, and have finally landed here (Revolved Curve.dwg). This is exactly how I want the horn to look when I print (Ideally I'd like to model it to look like a gramophone horn, but that is not necessary at this point) So, I try to export the horn to STL format, but get the error "Selected Objects must be solids or watertight meshes". Which makes sense still. So I have tried a number of ways to convert to solid, or surfaces (I'm not sure the difference, but I'd have thought that I don't want the horn to be a solid as I'd loose the internal cavity, wouldn't I?)
Anyways, when I try to convert to either, I am told "Can not convert an open curve" when using the 'Convert to Solid' option in 3D Operations menu, and simply 'Objects can not be converted' when I try to convert to a surface, from the same menu. This is where I fall over. I can't for the life of me work out how to convert to a solid or surface in order to export to STL.
My University are unable to help with autocad specific problems as its not an affiliated piece of software (seems a cop out to me) and have suggested I use their recommeded software (Blender), however this does not have the facility to execute scripts (This is how the curve has been generated).
Absolutely any help or advice would be massively appreciated as i am at a total dead end!
Tony.
