LandscapeArchitectFIU
1104 Vistas, 6 Respuestas
Insert Table Mac AutoCad 2015
Greetings,
I have looked through youtube, linda.com, google... I can't find a solution for this issue.
I need to insert a table for Planting Details for landscape design. But when I click on "Draw" then "Table" it
just wants me to pick a first point, then a second point. The Table is tiny and the text is not scaled correctly.
I can't find the properties tab so that I can insert the exact number of rows and columns , and the size text I need.
PLEASE HELP! I'll stay logged into this forum hoping for an answer....
Sincerely,
student.
maxim_k
en respuesta a: LandscapeArchitectFIU
Have you seen this tutorial?
https://www.youtube.com/watch?v=m5hG9plFuz0
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Yes! That does help. This is my screen shot... I found the properties inspector... but the columns and rows is still "greyed" out. ? I just figured out I can "scale" it up and it does scale the text with it too. Is this just a limitation of the mac version??
maxim_k
In AutoCAD you can set the number of rows and columns only during creation by dragging the mouse after you pick insertion point.
You cannot adjust number of columns / rows in Properties palette, this is "by design" and the numbers you see in the palette are for information only.
You can add / delete columns / rows via Table Visor which activates when you pick inside the sell and it highlights with the border.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Okay, I think I understand. When I pick a point .... hmm... what command do I use to set the number of columns and rows?
Okay, I read that solution again. It seems like in the other versions of auto cad that some of the other versions (may PC ) that it allows them to choose the number of rows and columns etc. Is that right ??
maxim_k
Yes, you can set the number of rows - columns in PC version of AutoCAD during creation in "Insert table" dialog.
But in AutoCAD for Mac there is no such dialog and you can set number of rows - columns during table creation only by dragging mouse (dynamically on screen) after you pick the insertion point.
In AutoCAD for Windows you cannot adjust the number of rows / columns in Properties palette as in AutoCAD for Mac.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
