- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You can use BREAK command for this:
https://knowledge.autodesk.com/support/autocad-lt-for-mac/learn-explore/caas/CloudHelp/cloudhelp/201...
You have to use it for each line separately.
There also should be a button on Tool Sets palette "Break at point" which uses the macro based on BREAK command.
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I've tried that before posting, but it just doesn't work how I'd expect. Maybe that's where my question should be focused--
When I initiate the BREAK command, it prompts me to select the object, so I select the line I want to break. But it auto-sets wherever I clicked as the first breaking point--not particularly useful as I cannot select an intersection when selecting the object originally. So, after I click the object, I have to type 'F' for first break point. From here I can click the intersection, it prompts for the second point, then it splits the line.
I've also tried selecting the line before the BREAK command. It just clears my selection and makes me select the object, type 'F', click first point, click second point.
Am I missing something? Is there some way to change the default behavior to let me select the object before BREAK, or at least default to "select first point" instead of auto-selecting wherever I clicked the object?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
There also should be a button on Tool Sets palette "Break at point" which uses the macro based on BREAK command. This macro asks for the object to break, than it prompts for break point and assigns it to the first and second points.
Do you see this button?
If no - than try to add it by customizing Toolsets palette.
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I saw it and clicked it, but it works the same way.
It makes me select the object, then it auto-defaults the first point to wherever I clicked. Any way to get it to immediately prompt for 'select first break point' after selecting the object?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you so much for your help (and your patience...)!
Here's a screenshot. (REMOVED: SEE NEXT POST)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
My apologies--you said "BREAK AT POINT" not just break.
Screenshot attached.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The only one additional condition - turn off object snap temporary before using this macro (button).
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Even with snap off, it's still doing the same thing. I turned off snap, clicked the BREAK button, selected the object, and it defaulted to where I clicked the object.
I'm using TRIM for now, it's faster than the way BREAK works, but I'm sure there's a better way!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
OK--sorry for all this double-posting, but I just noticed that clicking and holding the BREAK button brings up BREAK AT POINT. That function works mostly like the way I'd expect; however, is there a function I can type? I'd prefer to type the function than click a button.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
On the other hand you can try to use shortcut assignment to the menu item as in Mac OS shortcut assignment is a feature built in OS.
So, add "Break at point" command to the menu using CUI command in AutoCAD, than go to MacOS System Preferences (Keyboard pane) and on Shortcuts tab assign some shortcut to "Break at point" menu item in AutoCAD LT application.
Now you can use new shortcut in AutoCAD to call "Break at point" macro.
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Awesome idea--the shortcut works beautifully.
Knowing that CUI function will also come in very handy.
Thank you!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
select all intersecting lines and polylines and explode..
purge and save it as dwg file...
Save it again but as a dxf file...
Open staad pro..
import/export dxf..
Structure Convention, chose Y Up..
Choose appropriate Units..
Select all lines in staad pro..
in Geometry Tab select INTERSECT SELECTED BEAMS..
in the File Tab selct IMPORT/EXPORT..
Export as 3D DXF File..
Provide File name for the dxf file..
in Structure convention, chose Z UP..
Open in autocad the generated dxf file from staad and remove all unnecessary text..
may it helps you..
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
For years now I've been wondering why autocad can't break multiple lines by picking a cutting edge, right clicking, then using a crossing window to cut lines, where both sides of the line that was cut remain. It could be added as a trim option or mode.
Terramodel, ancient software from the 90s could do this.
But maybe I just never figured out how to ask google how to do this. Forums have provided zero help with this without some elaborate process where I could use the clunky break, first, second command and do it a few dozen times and still be quicker than the workaround.
Any updates with this?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
https://help.autodesk.com/view/ACDMAC/2023/ENU/?guid=GUID-7F63FF08-BF72-4975-8AFA-B6B3DC058F35
You can tell Autodesk to add any functionality you want yourself (no one here is able to do that for you) over here https://www.autodesk.com/company/contact-us/product-feedback
If you are running full AutoCAD, not LT, you can automate with LISP (free to you as a user), or find a LISP from someone else on the web that already figured out the code, like these perhaps
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/break-multiple-lines-at-point-of-int...
http://www.lee-mac.com/objectbreak.html
https://www.cadforum.cz/en/qaID.asp?tip=5632
https://www.cadtutor.net/forum/topic/25534-breaking-multiple-lines-using-a-cross-line/
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Yes, I have understood the limits of the break and trim command for about 20 years now. That's kinda the point I'm making.
My point stands that it is a simple action that even ancient software offered. And yeah, one person using a contact us page has historically done......nothing. lol
Thanks for the links though
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@ebaker72.eb wrote:
...My point stands that it is a simple action that even ancient software offered. ...
Indeed, if it was simple, or if thousands and thousands of users asked for it, it would be there now for sure.
That's all I stated. I also don't wait for anyone, if I want something I make it happen (LISP in this case).
@ebaker72.eb wrote:
... for about 20 years now..
As are most of us answering posts around here: 33+years for me. LISP and more are on offer for us users to go beyond the boxed package.
