en respuesta a: maxim_k
Thank you, worked flawlessly, it was not working because I was not hitting ENTER after each selection.
So in case anyone has the same problem later on I:
1) Drew a rectangle on a larger cube in order to resemble a door
2) EXTRUDE the rectangle into the cube a little bit
3) Subtracted out the newly extruded shape (using Maxim's commands above)
4) Re-drew a rectangle at the surface of the cube where it originally was
5) Hatched the newly drawn rectangle to create a metal looking door on an already hatched brick building
