- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I first drew a large rectangle that I hatched with a brick pattern. Then, I drew a two smaller rectangles inside the larger one to serve as a double door, and I hatched this with a solid color. It appears that the door hatch is constantly underlapping/overlapping the other brick hatch whenever I zoom in and out in model and paperspace. If I use the command REGEN it is completely solid, then I zoom out a little and it's partially solid, use REGEN again and its solid, etc. I don't know if it is because they are on the same plane and are competing with each other, perhaps there is a way to set one over the other without physically moving the door outwards along the Z axis?
I've attached a pdf of what my problem looks like. Thanks for the help!
¡Resuelto! Ir a solución.
