03-13-2017
10:00 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-13-2017
10:00 AM
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Did applying a Page Setup as @maxim_k suggested fix the problem?
It appears that you are using the Adobe PDF printer driver. If you try a Print and then select Save as PDF from the dialog lower left corner, does it still not work properly?
If all you are getting is a white page I suspect that you have not configured the area to be plotted/printed.
You are welcome to attach a file here for me to examine.
John Vellek
