- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Adobe PDF Printer Not Working
Today, my AutoCADLT for Mac stopped being able to plot to PDF. I tried exporting as a PDF and it says a blank page. I also tried printing and selecting "Print as PDF" and the same blank page is exported. Would greatly appreciate any help. Working on a freelance project and need to send PDFs to my client. I attached a screenshot of the error message that pops up when I select "Print."
Thanks!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Before exporting to PDF you need to setup Page Setup with Page Setup Manager for each of the Layouts you want to export.
I think each time you will edit Page Setup in Page Setup Manager you will get the warning you posted, but after editing the warning should go away and you will be able to export to PDF.
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Did applying a Page Setup as @maxim_k suggested fix the problem?
It appears that you are using the Adobe PDF printer driver. If you try a Print and then select Save as PDF from the dialog lower left corner, does it still not work properly?
If all you are getting is a white page I suspect that you have not configured the area to be plotted/printed.
You are welcome to attach a file here for me to examine.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
HI @Anonymous,
I am checking back to see if my post or @maxim_k's helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
