kristinabhalter
1571 Vistas, 5 Respuestas
Plot DWG to PDF .shx font doubles in Mac Preview
Hello-  I am trying to solve this problem.  I have already switched pdf options in all variables, to change the text to geometry, etc.  The result is always the same.  When I plot DWG to PDF in plot style, the resulting image in Preview on Windows side looks good, when I open it in Preview on Mac side, the text shows double, written twice in 2 different fonts, the original font and a smaller, different version.   And TrueType Font does not show up at all on the Mac PDF.
attachment included
maxim_k
en respuesta a: kristinabhalter
This is knowing issue with Preview app on macOS since Yosemite.
In case when you are viewing PDF file (created in AutoCAD with searchable text feature enabled) in Preview application on Mac you will see "double" text.
Searchable text feature was introduced in AutoCAD 2016 for Windows and than in AutoCAD 2017 for Mac.
There are two workarounds:
- view PDF files on Mac with Adobe Reader - than you will not see "double" text
- turn off searchable text feature by setting AutoCAD System variable EPDFSHX=0. Than searchable text will not be created in PDF and text, ctreated with SXH based Text Style will look correctly.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Re: Plot DWG to PDF .shx font doubles in Mac Preview
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi Thomas,
The issue with Preview is still here and I understand that you cannot force consultants to turn off "searchable SHX" text feature.
So there is still only one solution - use third party PDF viewer to view PDF files, created in AutoCAD.
I use PDF Expert application, which I like more then Acrobat reader.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Thanx Maxim!
I’ve tried PDFPen but it has a related issue - all those characters get framed.
What I don’t understand is why Apple don’t fix it. They obviously know how. Finder’s Quicklook is OK, and Preview was working fine in previous OSXs.
This sucks!
Thomas
