maxim_k
en respuesta a: shawnmayers
Welcome to Autodesk Forums!
I believe you are working with DWG files placed in the folder which is connected to iCloud some way - this could be iCloud Drive folder or Documents and Desktop folders connected to iCloud via iCloud pane in macOS System Preferences.
If I'm right, than it is knowing issue and the only one workaround is to keep drawings you are working on in the folder which is not connected to iCloud.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
