466 Vistas, 5 Respuestas
How to use auto cad lt on mac ?
My mac does not responding on auto cad lt. what can I do know ?
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Can you provide more details about your problem?
when it doesn't respond? At launch, when you open existing DWG file, when you print or?
Please specify also AutoCAD LT version and macOS version.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Emmsleys
If possible can you provide the following information:
  • What AutoCAD release are you workign with?
  • What OS are you running? Sierra? EL Captain?
  • What exactly is happening? Is AutoCAD not starting when you try to run the program?
Sarah Emmsley
Technical Support Specialist
Emmsleys
To add,
Try the following:
Apply all updates to AutoCAD
Make sure you are running with full admin rights.
If possible provide screenshots of your issue or a screencast video.
Sarah Emmsley
john.vellek
Hi @Anonymous,
If you are running Sierra on your Mac, I suggest that you remove your current installation and then re-download  your application to install it fresh.  If this doesn't work for you have you tried installing a full AutoCAD trial to see if it performs differently?
Do you have any applications running (such as anti-virus) that might be preventing the install from completing?
Please provide a bit more detail so I can help you get up and running.
OS version:
AutoCAD LT version:
John Vellek
Emmsleys
Did any of the posts in the thread help with the issue?
Please use the
Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Sarah Emmsley
