400 Vistas, 3 Respuestas
auto cad dose not save files
Hi Everyone,
I don't know why, but my Autocad 2015 does not save as any new files I'm trying to add.
I'd tried to restart my Mac but it didn't help.
Thanks!
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Where you are trying to save your files? Local drive, network drive?
What do you see from AutoCAD when you are trying to save file? Any alerts?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Emmsleys
Following up on your thread, were you able to find a solution? Or a workaround?
Did any of the posts in the thread help with your issue?
Please post back in the thread if you are still having an issue with AutoCAD or Select Accept as Solution for the post’s that helped.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
Emmsleys
en respuesta a: Emmsleys
To add;
There is no Autodesk folder in the Documents directory. Usually, there is an Autosave folder within the Autodesk folder that resides in the Documents folder. On some systems, though, these folders do not get created, so the program writes the backup and autosave files into the Documents directory.
Suggested solution:
Create and Autodesk folder in the Documents directory, and create a folder inside of it called Autosave.
Resource to look over;
AutoCAD for Mac writes backup and autosave files to the Documents folder.
Sarah Emmsley
