maxim_k
en respuesta a: stephenUHJNW
When you print with Batch Publish, AutoCAD doesn't use OS printing system. That is why it can print with Batch Publish.
So looks like there is some issue between AutoCAD and current state of macOS printing system. You can try to Reset printing system in macOS System Preferences:
https://support.apple.com/en-us/HT203343
Look for step #4 in "If your Mac has some other issue with your printer or scanner" section.
This will remove all printing software and you will need to install it again. Try to find the latest printing software compatible with Sierra for your print devices - you may look for it on the printer/plotter manufacturer's website.
After reinstalling printing software you can test Print functionality in AutoCAD again.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
