2518 Vistas, 4 Respuestas
Display Layout Elements
I am using this software on a MAC. At school we are using
windows and we changed some settings from the display options menu to
make the Layout paper disappear. We unticked the; Display printable
area; Display paper background; Show Page Setup Manager for new
layouts; and Create viewport in new layouts. Is it possible or is
there a different way to do this on a MAC? Note that I am using the
2015 AutoCAD for MAC.
Thanks and Regards,
IMG_0467.JPGLuke Farrugia
maxim_k
en respuesta a: Anonymous
Hi Luke,
In AutoCAD for Mac 2015:
1/ To disable Display printable area:
At the command prompt type: (setenv "ShowPaperMargins" "0") and hit Return:
Command: (setenv "ShowPaperMargins" "0")
"0"
Command:
2/ To disable Display paper background:
At the command prompt type: (setenv "ShowPaperBackground" "0") and hit Return:
Command: (setenv "ShowPaperBackground" "0")
"0"
Command:
Than at the command prompt type: (setenv "ShowPrintBorder" "0") and hit Return:
Command: (setenv "ShowPrintBorder" "0")
"0"
Command:
Than Restart AutoCAD or reopen currently opened drawings in order the new settings take effect.
3/ Show Page Setup Manager  - disabled by default in AutoCAD Preferences:2017-02-01_13-40-52.png
4/ To disable Create viewport in new layouts - use the same tab of AutoCAD Preferences window as shown above - uncheck "Create viewport in new layouts"
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
I would like to thank you for your kind help, but unfortunately I am not managing to enter the commands you are asking me to input. Nothing is happening  when I input for example; setenv "ShowPaperMargins" "0". Is it possible please to be a bit more clear for me to understand? Sorry for the inconvenience.
Luke Farrugia
maxim_k
Luke,
You need to ensure that no command is running an at the command window you see the word Command:
Now type with keyboard later by letter:
Yes, you need to start with round bracke, than letter s, than letter explaining, etc. As soon as you type round bracket at the end, hit Return
Now repeat with next 2 variables.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Thanks a lot for your help it worked finally.
Luke Farrugia
