lionel.bekale
en respuesta a: LormansDesign
Hi LormansDesign,
Welcome to the AutoCAD for Mac forum.
I have seen your post today. I understand that you got the following error message when AutoCAD starts.
<<AutoCAD for Mac error : "Exception in AcExperience.bundle ARX command">>
You also fixed the problem later by deleting the following folders In Library/Application Support/Autodesk folder:
"2017" in "ACDLTM"
"2017" in "ADUT"
"AutoCAD LT 2017" in "Web Services"
However, when you uninstall the software on the Mac you should do the following:
Exception errors in ARX command can be due to damaged file within AutoCAD or due to some ObjectARX applications that do not load properly. Therefore, re-installing AutoCAD as described above may also fix it. Please have a look at this help document ARX (Command)
Hope it helps.
Lionel Bekale
Technical Support Specialist
Link Name
