- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi I'm using AutoCad LT for Mac 2017 and running on Os X El Capitan Version 10.11.6
- Plot styles are not printing correctly to a PDF. I've tried same file on 2016 and everything prints normally. See attached files
- Print plot styles is checked
- Scale lineweights is checked
- The .ctb file is pathed correctly
- correct .ctb file is selected
Please let me know if you there is something I can do to address the issue.
Thank you,
Brian
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I was able to resolve this issue by unchecking the box "scale lineweights" .
This was never an issue for me with previous releases.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I am having this same issue and can confirm that unchecking the 'Scale Lineweights' box does allow lineweights to plot properly if your scale is set to 1 to 1.
Is this a bug or an intentional change?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Same problem, but the application could no longer find the .ctb search path. When I try to reset the search path I'm unable to click on the .ctb file - it's shown as inactive (grayed out) in my desktop folder. See screenshot images below. How do I reset the file search path? (FYI, the problem started after I turned off iCloud because it was causing other problems.) I'm running on OS Sierra version 10.12.3
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
If the second screenshot shows the window which appears when you want to add the path, you need to select in it the folder where the CTB file is placed, but not the CTB file itself. That is why CTB (and other files) is grayed out.
Maxim
Maxim Kanaev
Architect
MARSS
