Emmsleys
en respuesta a: t_leis
You could try the following:
  • Set each layer on/thawed
  • Freeze all the other layers,
  • Then WBLOCK (for DWG)
  • Then in the dialog box that shows up, manually select the objects on screen to create unique single-layer files for each layer you want.
Sarah Emmsley
Technical Support Specialist
