t_leis
482 Vistas, 4 Respuestas
Autocad LT for Mac 2016
Hi Team,
I have a client that provide me a dwg file so I can view them and change it. My question is,  can I take some layers of that file and exported to another file of dwg?
Emmsleys
en respuesta a: t_leis
You could try the following:
  • Set each layer on/thawed
  • Freeze all the other layers,
  • Then WBLOCK (for DWG)
  • Then in the dialog box that shows up, manually select the objects on screen to create unique single-layer files for each layer you want.
Sarah Emmsley
Technical Support Specialist
t_leis
en respuesta a: Emmsleys
My client did the following and took screen shots as I proceeded…. There wasn’t a file created.
maxim_k
In the client's file find objects which are on the Layers you want to have in another drawing, or create a couple of lines on these layers.
Than copy these objects (or lines drawing by you) to clipboard, than paste them to another drawing, than you can erase pasted objects and the Lakers from client's drawing will stay in your drawing.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Emmsleys
Were you able to try the suggestions Maxim made?
Sarah Emmsley
