maxim_k
en respuesta a: Anonymous
I cannot reproduce such issue (same OS and same AutoCAD).
I tested with two printers: one connected directly via USB port and other one is network plotter connected to the network via print server. In both cases I can print directly from AutoCAD to physical device without "PDF stage".
You mentioned Adobe software. Do you have Adobe Acrobat pro or Adobe Reader? If you have Acrobat Pro, does it install some "PDF output" software?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
