maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi Ak,
You need to fine tune text height in the current dimension style:
Use menu Format -> Dimension Style,
Than select "Modify" from "gear" menu:
Go to the "Text" tab and set text height:
Note that in order to be able to set text height in the Dim Style window, Text Style which you use in this dimension style should have zero height.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
