10-29-2016
08:36 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-29-2016
08:36 AM
Welcome to Autodesk Forums!
You need to change settings in LAYFRZ command in such a way that it uses the option "Vpfreeze" instead of "Freeze".
Look at the command prompt options you need to type (marked in red):
Command: LAYFRZ Current settings: Viewports=Vpfreeze, Block nesting level=None Select an object on the layer to be frozen or [Settings/Undo]S Enter setting type for [Viewports/Block selection]V In paper space viewport use [Freeze/Vpfreeze] <Vpfreeze>: V Select an object on the layer to be frozen or [Settings/Undo]TEXT Layer "TEXT" has been frozen in this viewport. Select an object on the layer to be frozen or [Settings/Undo] Command:
Maxim
Maxim Kanaev
Architect
MARSS
