576 Vistas, 7 Respuestas
Sheet Set Manager: Poor Performance on Network
Aloha,
Our office has been having issues with performance when accessing a file located on a shared drive on a Mac Server (10.11.6) and Server version 5.1.7. When the user attempts to access the file, the Sheet Set Manager beachballs, runs slow, and sometimes the application has to be Force Quit. Do you have any recommendations on how to alleviate or or correct this problem?
Please let me know if more information is required. Using AutoCAD for Mac 2016.
Emmsleys
en respuesta a: Anonymous
Aloha @Anonymous,
Have you noticed if this happens with all files or a specific few?
Have you applied all updates to AutoCAD 2016?
Sarah Emmsley
Technical Support Specialist
en respuesta a: Emmsleys
Hi, yes we've installed all of the updates. It happens only when the .dwg's and .dst's are located on the network as described above. We do not run into this issue when accessing .dwg's and .dst's on the local drive.
maxim_k
What network protocol are you using?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
SMB
maxim_k
SMB should work according to official information.
To say true, I newer tried to use Project manager over network, maybe there is still some bug in AC for mac related to this.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Hi @Emmsleys,
Does Autodesk have any leads on a solution?  We have installed all of the updates. It happens for projects when the .dwg and .dst are located in the network. As @maxim_k asked, we have an SMB network, and he hasn't run into this issue before and it might be a bug with AC for Mac.
Emmsleys
@Anonymous,
I can log a defect for this issue. Let me do some additional research and circle back to this thread.
Sarah Emmsley
