344 Vistas, 4 Respuestas
snapping problems
Our school has been using autodesk autocad for mac for a couple of years and have had no problems until this week.
My students are having trouble with snapping to a point and the lines seem to jump on them.
Any suggestions?  Thanks, Scott
maxim_k
en respuesta a: Anonymous
Hi Scott,
Can you illustrate somehow the issue?
What do you mean by "lines jump on them (points)"?
Which OS installed on their Macs?
Do they upgraded to a new macOS Sierra by chance?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
When we snap lines to specific points, the lines don't end up exactly on that point.  When magnified they are off a little.
maxim_k
If you are using object snap try to use REGEN command when you zoom in and you will see that it snaps correctly.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Emmsleys
Hi @Anonymous,
If it helps to make a video to better explain your issue you can use Screencast. It is a free application which can be dowloaded here: https://knowledge.autodesk.com/community/screencast
Sarah Emmsley
Technical Support Specialist
