maxim_k
en respuesta a: Anonymous
To change the size of font of one dimension you can use Properties palette - select dimension, than look for the Text section in the Properties palette -> than change text height.
To change text height for all dimensions of the particular dimension style - use menu Format -> Dimension style, than select dimension style you want to change an select Modify from "Gear" menu.
Just remember - if you want to be able to change text height in dimension, you need to assign text style with text height=0 (zero) to this dimension style.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
