307 Vistas, 3 Respuestas
Dimension Style
I am unable to alter the Dimension Style.
I have tried the Command Line and the drop down but I type the words in / or click but nothing happens ... it used to !
Any ideas ?
Andy
maxim_k
en respuesta a: Anonymous
Hi Andy,
It is not clear from your post: do you want to change something in particular dimension object, or you want to change settings for the dimension style globally?
What do you mean by "I type the words in / or click but nothing happens"? Where you type words or where you click?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Hi Maxim,
I just want to change the size and font of a dimension.
Neither the Command box or the Drop down menu react when I either type the command or click on the menu (which it used to ), so  how do I change the Dimension style now ?
Andy
maxim_k
To change the size of font of one dimension you can use Properties palette - select dimension, than look for the Text section in the Properties palette -> than change text height.
To change text height for all dimensions of the particular dimension style - use menu Format -> Dimension style, than select dimension style you want to change an select Modify from "Gear" menu.
Just remember - if you want to be able to change text height in dimension, you need to assign text style with text height=0 (zero) to this dimension style.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
