6398 Vistas, 14 Respuestas
Jagged lines when printing to pdf on Autocad LT for Mac
Hi all,
I'm having issues with lines turning jagged, when printing/exporting to PDF. The lines are perfectly normal in Autocad, but on PDF they turn messy and makes the document hard to read. This seems to be an issue especially near viewport edges and on certain dashed lines. When printing on paper, most of the lines look fine, but some will still have slightly thicker spots.
Has anyone had the same issue? I check the previous discussion, where the problem was solved by changing the line join style to "use object join style", but that didn't help in my case.
Tanks in advance!
Mari
