536 Vistas, 3 Respuestas
AutoCAD Mac 2016 Plot Scaling problem
I'm experiencing a really weird issue with AC 2016 on my Mac. Since updating from 2014 a couple weeks ago, I cannot get it to plot correctly when using engineering scales. A document which plots normally when set to 1/8":1' or 1/4":1' goes completely off at 1:10 or 1:20. It actually gets larger when I select 20 scale than it is at 1/8", when it should get smaller. I've checked the scale settings and they are correct; 1:20 is one paper unit for 20 drawing units.
I tried creating an entirely new drawing and the results are the same. Everything measures out correctly but refuses to plot to scale.
I attached screenshots of the two different scale settings; use the pile of rocks and the word "Waste" in the center of the box in the 1/8th scale image, since the box outgrows the page at 20 scale. I also included a screen shot of the layout settings.
It's probably something really simple that I've overlooked, but any help would be appreciated. Thanks
maxim_k
en respuesta a: Anonymous
The 1/8" : 1' scale has scale factor 96:
Invert the fraction and multiply by 12. 8/1 x 12, you will get scale factor 96, but not 20.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Emmsleys
Hi @ jon_crowe,
Following up on your post were you able to adjust your scale settings to what you need it to be?
Please post back with any updates. Thanks
Sarah Emmsley
Technical Support Specialist
Emmsleys
Feel free to post back in the thread should you have any other questions.
Thanks.
Sarah Emmsley
