2281 Vistas, 3 Respuestas
Autocad muestra cuadros negros por cuando inserto una imagen.
Buen día, lo que sucede es que cuando inserto una imagen en AutoCad 2015 e intento imprimir, está se muestra solo como un cuadro negro. Esto pasó desde que actualice al nuevo sistema MacOS Sierra. ¿A alguien más le sucede esto y ha encontrado alguna solución?
Saludos!
Etiquetas (1)
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
AutoCAD 2015 for Mac is not compatible with macOS Sierra. The issue you have is one of the results of the incompatibility.
Please look also here:
http://forums.autodesk.com/t5/autocad-for-mac-forum/black-box-appearing-on-xref-images-when-plotting...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Emmsleys
Currently AutoCAD is not supported on the new Mac OS.
Please look to the link Maxim has suggested and I will also do my best to circle back to this thread with any new updates.
Thanks.
Sarah Emmsley
Technical Support Specialist
bryce.thelin
Here is a new article we have about this problem:
Images in referenced files do not plot in AutoCAD for Mac on Mac OS 10.12 (Sierra)
There is no ETA yet on when an update will be available to fix Sierra compatibility issues, but AutoCAD will notify you as soon as it is available. If your computer is mission critical for AutoCAD and none of the workarounds suggested in the article help, then I would suggest using Time Machine and rolling back your system to what it was before Sierra.
Bryce Thelin
AutoCAD Product Support
