256 Vistas, 1 Respuesta
MText Subscripting
Afternoon,
I'm wanting to add subscript in MText. I want to label R1 R2 R3 R4 but all the number need to be subscripted. I can make R2 subscripted because there is the default option but how do I edit the other numbers?
Thanks very much.
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
In the MTEXT editor write the index text as a stacked text - e.g. 2nd/xx hole (if you have AutoStack disabled, select the text to stack - nd/xx, right click and choose 'Stack'). Select the stacked text, right click and choose 'Stack Properties'. Delete nominator or denominator of the stack (e.g. xx). Set the 'Style' to 'Tolerance'.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
