421 Vistas, 7 Respuestas
Replaced hardrive on Mac with SSD - now can not open drawings
I have tried the following: https://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticle...
But It still tells me that the drawings needs to be verified. I really need to use the program now. Can someone help, please.
Regards
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
From your post I cannot be sure: are you able to launch AutoCAD and save newly created drawing?
If yes, what kind of alert you get when you open your old drawings? Please attach screenshot.
Macim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Hi maxim_K,
Thanx for the response. I do not want to talk to fast but it seems that I have managed to sort out the problem. I removed AutoCad again from my laptop, the one that was restored. Then I did a complete new download from Autodesk site. Installed it and opened a DWG that was on my mac. So to answer your question, I was not able to open drawings that was on my mac, old drawings. I did not try to just open Autocad and open a blank drawing. When I wanted to open an old drawing it said that the drawing needed to be authenticated (My wording might not be 100% correct) sorry did not take a screen shot. I wanted to take one now, but then it opened, hence the reason I say I think I have solved the problem.
I will update the post if I encounter an issue again later today.
Regards
maxim_k
Good news!
Post back if you will have troubles.
BTW: which application you used to migrate your HDD?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
I did a back-up on timemachine and then just restored the backup to the new SSD.
maxim_k
Thanks for the information.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Makes a huge difference, I would strongly recommend it. I installed a HD-SN500-750E Samsung (Evo Series)
Emmsleys
@Anonymous Thanks for sharing what worked.
If you have any other findings post back when you have time.
Thanks.
Sarah Emmsley
Technical Support Specialist
