1850 Vistas, 7 Respuestas
Cannot turn off automatic creation of constraints
Running Acad for Mac 2011-cannot upgrade because of older OS. Constraints seem to be created constantly though I keep deleting them. I don't want to use constraints but system won't let me turn off all geometric constraints; requires at least one. I have tried delconstraint, managing constraints from the pulldowns (doesn't seem to be a variable to turn autoconstraint off altogether). I delete all constraints and they appear again immediately. Others described problem but the solution that worked for them doesn't work for me. Is this a bug? How do I turn off creation of new restraints after I have deleted them all?
Etiquetas (2)
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
You need to turn off Infer Constraints mode on the Status Bar:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Thank you for responding-it is off, I have only what I need on the status
bar open. Is there some other system variable or another place to turn it
off? Thanks!
*Julia Hines*
Jgrayhines@gmail.com
Emmsleys
Hi @ Jgrayhines,
Is the CONSTRAINTINFER system variable is set to 1 or 0?
Sarah Emmsley
Technical Support Specialist
Emmsleys
Are you able to test this issue in a different environment on your system as a new user?
Have you tried the suggestions made here
Post back should this not resolve your issue.
Sarah Emmsley
maxim_k
Please check CONSTRAINTINFER System Variable:
http://help.autodesk.com/view/ACDMAC/2016/ENU/index.html?guid=GUID-71EC58F4-BBAD-444E-AF4D-ABDF6B038...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Using the system variable setting at command prompt fixed it! Thanks much!!!
Emmsleys
Thanks for posting back what worked.
Sarah Emmsley
