2470 Vistas, 2 Respuestas
Stretch, Add and Remove Vertex
I'm having a bad experience with 'Stretch, Add and Remove Vertex' grip menu. It slows my productivity when I slide de cursor to move or copy an object.
The menu pops up when the cursor passes over a grip.
Anyone knows how to turn it off? I've tried to disable grip tips, but nothing...
maxim_k
en respuesta a: Anonymous
You need to disable multifunctional grips by setting system variable GRIPMULTIFUNCTIONAL=1 or GRIPMULTIFUNCTIONAL=0.
Look for documentation here:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Thanks for the quick solution, maxim_k!
Problem solved.
