sapote
544 Vistas, 6 Respuestas
Re: AutoCAD LT 2016 MAC: SUPERHATCH leaving blank areas after selection...
Why is SUPERHATCH leaving blank areas as pictured? I've tried zooming out/pan, but it only made a difference once. Other times different areas are blank, but typically the same area is blank no matter how many times I try repeating SUPERHATCH selection. Tried turning off other hatch/fill = no difference. There's always some area left blank.
sapote
en respuesta a: sapote
Addendum:
I tried using Superhatch>Select Existing Object... then selecting the original hatch/image, also others, and it fills in the blanks, but with different sizes/scale of the original and looks even more repetitive. I also tried repeating the initial Superhatch>Image scale and selection but it does the same thing by filling in the blanks with varied size image hatch or doesn't work at all (trying it right now). I have no idea what's going on here. Please help.
On top of this, Object Snap keeps turning OFF and deselecting ALL Snap Mode settings. This has been happening for a few months now. Agggh!
sapote
It's leaving the same area blank on different elevations. WTF?!
maxim_k
Can you attach your drawing along with the image file you are trying to use with SUPERHATCH? I'll look at it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
sapote
en respuesta a: maxim_k
I will asap. I'm busy working on projects.
Emmsleys
If you have any new updates on the project or need additional help could you post the file?
Thanks.
Sarah Emmsley
Technical Support Specialist
Emmsleys
Following up on this thread, were you able to resolve your issue? Could you possibly share that with us in this thread?
If you are still having an issue with AutoCAD the community and I will be more than happy to help.
Sarah Emmsley
