1077 Vistas, 6 Respuestas
Text size and weight changes when printing or exporting
using ACAD LT Mac to design a corporate logo text is in Gil Sans Bold, when I export or print the text comes out smaller and non bold why?
pendean
en respuesta a: Anonymous
LT for MAC version is....?
MacOS you use is....?
"export" and "print" to what?
en respuesta a: pendean
10.11.5
ACAD LT 2016 M.48.M586
looking to export to a form that my sign company and other shirt printer can use as well as some form that can be inserted in to a word or excel doc for documents.
I was trying to export to .pdf
I also tried to print and print preview and had the same results
Eric Melrose
maxim_k
Hi Eric,
You need to try to install Update 2:
https://knowledge.autodesk.com/support/autocad-lt-for-mac/downloads/caas/downloads/content/autocad-l...
And than Update 3:
They should resolve text handling issues.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Downloaded updates and have the same results
Now what?
Eric Melrose
Eric Melrose, CEO
maxim_k
What if you will try to set system variable USEQUARTZFONT=0 when you print (save to PDF) the drawing with logo? This should force AutoCAD to outline TTF fonts when saving to PDF. Maybe the results would be better.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
That did the trick
Thank you for your help
Eric Melrose, CEO
Melrose Contracting Corp
