Emmsleys
en respuesta a: Emmsleys
Try the following for Duplicate Objects.
  1. ClickModify > Delete Duplicate Objects
  2. At the Select Objects prompt, use a selection method to select objects.
  3. Press Enter.
  4. Optional:
    • Specify a Tolerance value.
      Defines the value within which OVERKILL makes numeric comparisons for determining object duplication.
    • Select properties to ignore during object comparison.
    • Set additional options to optimize polyline segments, combine objects, or maintain associativity.
    • Click OK.
Sarah Emmsley
Technical Support Specialist
