08-19-2016
05:57 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-19-2016
05:57 PM
Need help on deleting duplicate items and unused objects?
Sarah Emmsley
Technical Support Specialist
¡Resuelto! Ir a solución.
08-19-2016
05:58 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
08-19-2016
05:58 PM
Try the following for Duplicate Objects.
- ClickModify > Delete Duplicate Objects
- At the Select Objects prompt, use a selection method to select objects.
- Press Enter.
- Optional:
- Specify a Tolerance value.
Defines the value within which OVERKILL makes numeric comparisons for determining object duplication.
- Select properties to ignore during object comparison.
- Set additional options to optimize polyline segments, combine objects, or maintain associativity.
- Click OK.
Sarah Emmsley
08-19-2016
05:58 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
08-19-2016
05:58 PM
Try the following for unused objects.
- At the Command prompt, enter purge.
- To purge unreferenced linetypes, use one of the following methods:
- To purge all unreferenced linetypes, select Linetypes.
- To purge specific linetypes, double-click Linetypes to expand the tree view. Then select the linetypes to be purged.
- You are prompted to confirm each item in the list. If you do not want to confirm each purge, clear the Confirm Each Item To Be Purged option.
- Click Purge.
Sarah Emmsley
