2597 Vistas, 7 Respuestas
Determining the Scale of a drawing
Hey there!
I am using AutoCAD for mac and have received a drawing from a client that they want me to edit and fix. I am having trouble drawing in this previous drawing with the right scale and dimensions. For example, I am trying to draw a rectangle with dimensions 32'x12' but when I try to even draw a line it says "polar" and a lot of numbers that don't fit in the scale I wish to use.
Could anyone help?
I am a new user and would appreciate a detailed description.
Thanks!
Emmsleys
en respuesta a: Anonymous
Would you be able to share a sample of the drawing file here? You can leave the bare minimum of the file if the concern for privacy is an issue.
Sarah Emmsley
Technical Support Specialist
Emmsleys
In addition you can look to the following links to see if this helps your issue;
SCALELISTEDIT (Command)
Custom scales not available in other drawings
Sarah Emmsley
maxim_k
Please attach screenshot of what you see, when you start to draw a line. I just want to find out what is "it says polar" in your case.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Here is a screen shot of the "polar" part...
Thank you!
oops, here is the screen shot
Emmsleys
Hi @Anonymous,
Try looking over the following let me know if this helps with the "polar" part.
AKN Forum thread
Polar tracking
Sarah Emmsley
Emmsleys
Additionally take a look at this help document ;
To Turn On and Turn Off Polar Tracking
Sarah Emmsley
